Morning,
say i want to copy & paste relative reference all of obj_A's transform parameters (tran/rot/scale/pivot etc) onto obj_B, is there a quick way to do it within Houdini? or will i have to use python or other programming languages…?
eitht.
Copy/Paste relative reference multiple parameters at one go
6840 4 2-
- eitht
- 257 posts
- eitht
- 257 posts
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=105978&sid=a9ea33efe4db9b68c4bce76214f5e910 [sidefx.com]
found this thread which is what i want but honestly the solution makes little sense to me since i got little experience with python (i'm going through resources from http://www.khanacademy.org/ [khanacademy.org] now).
Would be awesome if you guys could give some pointers or share resources here for peeps keen on learning python.
eitht.
eitht.
- zdimaria
- 390 posts
No expert here, and not sure how much you know already but-
For knowing absolutely nothing, I would recommend following this ebook / tut - http://learnpythonthehardway.org/book/ [learnpythonthehardway.org]
Once you have a basic understanding of Python, I would then highly reccomend you watch Luke Moore's Masterclass. https://vimeo.com/14612897 [vimeo.com]
If you prefer a book book, (as I did), I would reccomend Beginning Python: From Novice to Professional by Magnus Lie Hetland.
And then of course the hou reference in the docs is great as well.
for source, target in zip(source_tuple, target_tuple):
source.set(target)
If you understand for loops, the only thing that may be new to you is zip. Its basically wrapping up 2 variables into a tuple, so that they may both be used in the for loop. If you don't understand for loops, I would start with the first tut at the top.
Hope this helps a bit… best of luck!
source.set(target)
- eitht
- 257 posts
Thank you zdimaria, i'll check them out - definitely want see how python could help me more. Up till now i've been following basics, hopefully it gets me excited enough when i use it practically!
Got another question, i'm aware some functions are being used/evaluated differently in python v3.0. Are people moving on to python v3.0 or is v2.0 still what most people (especially in production) use?
eitht.
eitht.
- zdimaria
- 390 posts
Im not in the real world yet so I don't know what people are using in production. I would assume, and make a strong guess that they are not using 3, and are likely using 2.6, maybe 2.7. I'm pretty sure H12 uses 2.6.4 internally.. and I don't see why studios would go through the extra effort to not use 2.6.
Again, though, not a real person yet, so all of this could be completely wrong. Maybe one of the pro-guys could chime in?
zak
zak
