so if you have a hidden folder and do not hide the parms on an Digital Asset the parms do not show up in the parameter interface. However, if you do a hou.pwd().parm('foo').isHidden() it returns ‘false’! What is the best way to check and see if that parm is actually displayed to the user - is there some hou.parmTemplate or hou.folderParmTemplate way.
I've been playing around with it but seems quite unintuitive - you would think that if a folder is hidden and the parms inside of it do not show up in the interface that the above command would return ‘true’.
Regardless, if there is a way to determine which parms are ‘hidden’ (ie. not showing up in the parameter interface and hou.pwd().parm('foo').isHidden() = false) that would be great at least I can work around this.
'hidden' parms in hidden folders on HDA
4346 2 2-
- are2d2
- 79 posts
- jhuitema
- 3 posts
I've run into this problem as well and I managed to get something working with a helper function like so:
It only checks for a single folder as is but it worked for my purposes. If you have multiple levels of folders that might or might not be invisible then you would need to modify the script.
This would be nice if SideFX could change the isHidden to be intuitive like you said. But for now hopefully the python script helps.
def is_parm_hidden(parm): """Determine whether the given parameter is hidden. Args: parm (hou.Parm): The parameter to check the visibility of. Returns: bool: Whether the parameter is hidden in the Parameter interface. """ is_hidden = False parm_template = parm.parmTemplate() if parm_template.isHidden(): # ignore invisible parameters is_hidden = True else: # ignore parameters in invisible folders node = parm.node() parm_template_group = node.parmTemplateGroup() try: parm_folder = parm_template_group.containingFolder( parm_template.name() ) except hou.OperationFailed: pass else: if parm_folder.isHidden(): is_hidden = True return is_hidden
- nd_sliu
- 30 posts
I had to combine solutions from multiple posts to get this working, but here's the snippet..
See is_parm_hidden and is_parm_disabled
It'd be great for the devs to add something built-in to the API to achieve a similar effect
from typing import List def get_indexed_parm_name(name: str, multiparm_instance_indices: List[str]): """ Convert something like my_int#_# to my_int2_3 based on the given multiparm indices :param name: name of the parameter to format :param multiparm_instance_indices: list of multiparm indices which can be obtained from hou.Parm :return: indexed parameter name based on current parameter context name """ indexed_parm_name = name multiparm_index = 0 pound_sign_index = name.find("#") while pound_sign_index != -1: index_value = multiparm_instance_indices[multiparm_index] indexed_parm_name = indexed_parm_name.replace("#", str(index_value), 1) multiparm_index += 1 pound_sign_index = indexed_parm_name.find("#") return indexed_parm_name def get_unindexed_parm_name(name: str, multiparm_instance_indices: List[int]): """ Convert something like my_string1_2 to my_string#_# :param name: name of the parameter to format :param multiparm_instance_indices: list of multiparm indices which can be obtained from hou.Parm :return: unindexed parameter name with pound signs from """ old_suffix_index = 0 for i in range(len(multiparm_instance_indices) - 1, -1, -1): index = multiparm_instance_indices[i] old_suffix = f"_{str(index)}" if i > 0 else str(index) old_suffix_index = name.rfind(old_suffix) name = name[:old_suffix_index] + name[old_suffix_index + len(old_suffix):] name = name[:old_suffix_index] + "_".join(["#"] * len(multiparm_instance_indices)) + name[old_suffix_index:] return name def _check_conditionals_in_hierarchy(parm: hou.Parm, func): """ Helper function to evaluate conditionals in a parm, respecting its parents' conditionals """ if func(parm): return True node = parm.node() parm_template_group = node.parmTemplateGroup() # Because parmTemplateGroup doesn't contain FolderSet, use name instead. The names are unique anyway. topmost_parms = [entry.name() for entry in parm_template_group.entries()] current_parm = parm while current_parm.parmTemplate().name() not in topmost_parms: parm_template_name = get_unindexed_parm_name(current_parm.parmTemplate().name(), current_parm.multiParmInstanceIndices()) if parm_template_group.find(parm_template_name): parent_folder = parm_template_group.containingFolder(parm_template_name) parent_folder_indexed_name = get_indexed_parm_name(parent_folder.name(), current_parm.multiParmInstanceIndices()) current_parm = node.parm(parent_folder_indexed_name) elif current_parm.isMultiParmInstance(): # Ramp positions (e.g ramp_1pos, ramp_2pos) have parent names that don't exactly match a pattern (e.g. ramp) # Use parentMultiParm to find the parent current_parm = current_parm.parentMultiParm() # If the parent parm template is invisible, the parm would be None if current_parm is None or func(current_parm): return True return False def is_parm_hidden(parm: hou.Parm): """ returns whether a parm is hidden within the entire hierarchy, respecting its parent folders' conditionals """ return _check_conditionals_in_hierarchy(parm, hou.Parm.isHidden) def is_parm_disabled(parm: hou.Parm): """ returns whether a parm is disabled or hidden within the entire definition hierarchy, respecting its parent folders' conditionals """ return _check_conditionals_in_hierarchy(parm, hou.Parm.isDisabled)
Edited by nd_sliu - Oct. 22, 2024 19:32:02
