microscopic wires
   5292   3   0
Hi community
Here is a finished piece (not so much a wip). Let me know what you think feedback is always appreciated.
used wire solver and orbolt x-ray shader
mpejak
Very nice! I keep meaning to figure out how to make spaghetti; any advice on how to create a nice bundle of wires? Also, if you want to avoid the bits that are extremely thin, you could add a small constant to the that random thickness, so it'd have that as a minimum width.
Thank you! and good advice.
Sure, so in short i created a set of wires. used an expression to animate them in y direction. threw them through a dopnetwork using wireobject, wire solver. at the end of the dop network i threw down a vortex force. In the “vortexforcecreateattrbiute” I used wave motion effects in the radius to get interesting formations played with the velocities and contour range.
you should really look at sams noodledefromer hip http://ihoudini.blogspot.com/2009/09/wire-solver-and-wire-deformer.html [ihoudini.blogspot.com]
Thats how i started. All in all its in the vortex force.
Like to see what you come up with!
mpejak
mpejak
