Is it possible to turn houdini apprentice FX into Escape/Basic version?
I've also see into the pipeline diagram (http://www.sidefx.com/index.php?option=com_content&task=view&id=1021&Itemid=270) [sidefx.com] that the “particles and dynamics” can be created in Houdini FX and then simulated and rendered in Houdini.
I want to know how this step works, you need to export a bgeo file?
How to create a fx in Houdini FX and then simulated it in Houdini Escape.
Houdini apprentice FX or Escape?
10222 9 1-
- jujut
- 11 posts
- ragupasta
- 349 posts
1. If you open your start menu (assuming it's windows), navigate to the Side Effects folder, you can fire up Houdini instead of Houdini FX.
If you were to write out particles to disk as points you could render them in Houdini, as at the end of the day, they are only points. You should be able to render out a sim if it is a bgeo (I think..), as it is just a geometry type and not a simulation network.
You can't simulate anything dynamic in Houdini by the look of the product guide, so even if you built the sim network in FX, Houdini product wouldn't support it.
- jujut
- 11 posts
Thank you for the reply ragupasta.
Actually i am on linux, but when i try to launch houdini or houdiniFx via the exe file situated into the bin folder, i've always a houdini FX version.
Ok for the simulation writed to the disk, but i don't understand if i look on the pipeline picture (http://www.sidefx.com/images/stories/products/overview/pipeline.png), [sidefx.com] it's notice that the vfx can be animated and simulated inside houdini. So is it possible to create VFX (setup/rig) inside houdini FX and then use it it?
- old_school
- 2540 posts
Houdini can definitely open and simulate a HoudiniFX file. No issues there.
If you want to work with a simulation, tweak settings, change sources, then you need to make an Obj or SOP HDA out of your DOP network. If you do this, then you can promote whatever parms from your DOP network up to the top obj/sop level and modify your sim.
Given that all sources are in SOPs, it is easy to make the HDA so you can feed in any sources (sources, pumps, colliders, etc) but you have to build this all in as you can not edit the DOP network in Houdini.
- jujut
- 11 posts
thanks jeff for the reply, i understand better now.
But i've always a problem when i try want to turn my apprentice FX version onto escape.
I am under linux ubuntu when i go inside the bin folder, i've one executable for houdini and one linked executable houdini FX. So when i launch houdini execute file or houdiniFX execute file i have always a FX version with all the dynamic and particle parameters. Is there a way to turn houdini FX into Houdini Escape on linux ubuntu?
- old_school
- 2540 posts
- rmagee
- 1428 posts
- HenrikGieselmann
- 51 posts
- old_school
- 2540 posts
- HenrikGieselmann
- 51 posts
