vdb white water
   6966   5   1
how to export vdb white water as a particle fluid surface and not as a volumetric smoke?
I find a way to export them as points, so how can i convert this into a mesh like with a particle fluid surface? how?
https://vimeo.com/63392564 [vimeo.com]
How?
If you have it as points now, does the Particle Fluid Surface SOP not work?
i resolved this by converting to a volume surface density
traiano
how did you go about doing this?
Houdini FX R&D Reel 2013
http://vimeo.com/gtapper/fxreel2013 [vimeo.com]
