I have a 100 m square flip tank created with the houdini 12.5 new ocean tool.
In my flipsolver under the volume motion tab I set it like this :
Smoothing : 0.3
Surface extrapolation :0.3
Volume Fraction Method : Voxel Area.
The volume velocity is taken by a “SourceVolume” from the fields created by the “OceanEvaluate” Node.
I increased the gravity too.
The result is like this :
http://www.vbkstudio.com/temp/animTest02.mov [vbkstudio.com]
the whitewater is added but you can see the global behavior of the particles.
I want more splashes !!!! and particles more “independent” of each other.
Can I decrease again the Smoothing and Surface extrapolation param ? Is there a risk that the solver become unstable?
Even if my FLIP sims look smoothy, Can I added setup the whitewater to be more splashy anyway ?
Thanks for your help.
Vincent
how to create more splashes in my ocean
8524 7 2-
- vbk!!!
- 383 posts
- CeeGee
- 222 posts
First i think you need more resolution in flip simulation,
you can try to change smooting to 0.125 or maybe lower insted of 0.3,
but with more resolution you will get more splash look
i did similar test https://vimeo.com/65490463 [vimeo.com]
Igor
Igor
- vbk!!!
- 383 posts
- vbk!!!
- 383 posts
- vbk!!!
- 383 posts
- CeeGee
- 222 posts
- vbk!!!
- 383 posts
- seal
- 1 posts
CeeGee
Igor
hi,flip shader is a custom?
