Houdini Apprentice select geometry issues
   10541   14   1
Hi everyone,
I'm having the strangest issue with Houdini, I can no long select the geometry that I'm working with. I changed the selection options to primitives, lines, points, etc. and I still can't select anything. I thought it might be an issue on start up but after I restarted the program I still got the same issue. I'm working on a Windows computer and I've never had this issue before until now. Is anyone else having a similar issue or does anyone know a way to fix this?
Many Thanks!
is the green select option turned off on the node?
Thanks for the quick response! Yes it is. I also can't select geometry when I'm inside the objects even when I have an edit node in place.
That sphere looks like a primitive type sphere, you need to change it to something like polygons to select the parts of it and edit it.
See if changing the type helps: Click on the sphere node and change the Primitive type to Polygon.
Ok Thanks I'll try that
I tried changing it to a polygon like you said but I'm afraid I still can't select the geometry. This is a baffling problem.
can you upload your scene file and we can have a look
This is an older scene file that I want to make some changes to the bottle design. Thank you for all your help.
bottle.hipnc (75.5 KB)
Sorry I added the file to the wrong area.
not sure why its not working - just selected some polygons on OsX & Houdini 12.5.453
Ok. I think I'll just uninstall Houdini and reinstall it to see if that fixes the problem. Thanks for all your help!
There was a problem with picking things with AMD hardware due to a driver bug in earlier 12.5 versions. A workaround was added in 12.5.383 to fix the problem, so if you're using an earlier version of Houdini with AMD hardware you'll need to upgrade to a build > 383 (I'd recommend the latest production build, 427).
If this doesn't apply to you, what graphics hardware/driver are you running?
I uninstalled Houdini and reinstalled it but I'm still getting the same problem unfortunately. The graphics card that I'm running is a Nvidia Quadro 4000.
I got it to work! (yay) I updated my driver for my graphics card and after updating it, Houdini is now allowing me to select the geometry. Thanks for all your help everyone!
Hi Everybody,
Also was having trouble selecting objects to show translate/rotate/scale widget in Scene View (selecting from any of the nodes in network), with a simple geometry with a few transforms and merge. I'm on Houdini 17.0.352 apprentice.
Thankfully, updating my GeForce Game Ready Driver to V 416.81 fixed the issue. I'd updated driver pretty recently before, maybe a week ago, but this version (Release date 11/8/2018) was the solution.
