I am using Houdini on WIndows 7 and set variable environment to change HOME location other path.
I would like to know how to do the same with macOSX.
I am not a Mac user so I am lost.
Any clue is welcome
Vincent
QUestion about Environment variable and MacOS
4105 5 2-
- vbk!!!
- 383 posts
- fsimerey
- 279 posts
- vbk!!!
- 383 posts
- fsimerey
- 279 posts
You can edit Houdini Shell.terminal in you houdini folder.
Line 15<string>cd /Library/Frameworks/Houdini.framework/Versions/12.5.483/Resources;source houdini_setup</string>
to this:<string>cd /Library/Frameworks/Houdini.framework/Versions/12.5.483/Resources;source houdini_setup;export HOME=“your_path”</string>
- vbk!!!
- 383 posts
- fsimerey
- 279 posts
