Superbabe!
7201 5 2-
- jimc
- 295 posts
- jimc
- 295 posts
Added face blendshapes to the rig. These were done using a whole series of Edit SOPs, with mirror turned on, and using the Sculpt and Edit tabs. For the Edit tab, I used the soft radius set to between 0.03 and 0.01 to make the point edits more natural.
Eyelashes were done with a DA I made that takes a surface as an input, creeps the curves along the surface and then creates the tubes over that. The DA can optionally render the tubes as curves instead with a VOP SOP to add in varying amounts of width to the curve.
- jimc
- 295 posts
Here's a little video of the rig in action. Starting at 11:00 you can see the face blendshapes being used.
http://vimeo.com/82502104 [vimeo.com]
- jimc
- 295 posts
- jimc
- 295 posts
- chevita
- 122 posts
