Crash of Houdini 13.0.237
   3959   3   0
I'm currently using the vc11 build.
There is a lot of crash but still manageable if I tread carefully.
Some of the most common crash I found is following(if Auto Update is on):
  • disconnect node in DOP network when display/render set to down stream nodes get disconnected.
    change display while in SOP network that used by AutoDopNetwork.( a particle field), including Alt-LMB to just set display.
    change current timeline frame before start frame of AutoDopNetwork, or just change start frame while Auto Update is on.( flipfluidobject's creation frame is expression bind to AutoDopNetwork's start frame, solve on creation is disabled. )
    always crash after alembic export finished using alembic rop.(doesn't seems to happen in vc9 build of 13.0.198.21 )
    I'd like to share the scene but it's a production scene, I wonder where is the crash dump/log saved so I can send those to the bug report? Houdini did dump a stack I think, but window gray out and Windows force to close it before I can copy paste it somewhere, I can use a ProcessExplorer to export a mini dump file, don't know if this would be more useful?
    System Spec:
    OS: Windows 7 Ent 64bits
    Intel Xeon X5690x2
    Mem: 88 GB
    GPU: Quadro 4000, Driver 320.92
Hi ho! On windows, the crashlog ends up at:
CUsers/username/AppData/Local/Temp/crash_username
Chris McSpurren
Just tried to crash it again, and no crashlog created at all.
On a side note, the original hip file is created with 13.0.198.21, and then later onto 13.0.237, when I try to reproduce with a simpler setup, I couldn't get it to crash, just the hip I worked on will crash and reproducible.
would mini dump from Process Explorer be helpful?
Sure - log a bug with whatever info you have. Thanks!
Chris McSpurren
