Nuke always put float type image planes in "other"
   4817   1   0
I have some float type image planes output from Houdini with exr format. When I bring that image into Nuke, Nuke seems merge all of the float type layers into “others” channel. This causes some problems when I shuffle those float type AOVs.
It's the same problem as this discussion.
http://forums.odforce.net/topic/12518-use-whole-passes-in-nuke/ [forums.odforce.net]
I can't to change my float AOV output to vector because I need to reduce channel numbers in Nuke and reduce the file size.
I am wondering is there a way to tell nuke not to merge those float type AOVs into “other”
or
Can Houdini output image planes with channel groups, for example, I can put all my float AOVs in “my_mask” group and nuke will load them as “my_mask” instead of “other”
Attach a hip file and exr
floatAov.exr.gz (250.4 KB)
floatAOV.hip (192.4 KB)
Same issue here, try to use expression node like that :
Red : other.nameOfYourAov1
Blue : other.nameOfYourAov2
Etc….
This is a clean way to find yours aovs.
Next you can use remove node to clear nuke's buffer
Happy new year
http://www.papicrunch.net/GC-houdb/ [papicrunch.net]
