Calling dso-declared functions from a vfl
   2966   2   1
I had what is hopefully a quick question about dsos being used by vfl files.
I have a compiled dso, and in my vfl I am calling one of the functions that my dso declares. When using vcc to compile my vfl, it states that my function is undefined.
From within a houdini shell I can run:
$HFS/bin/vcc -X cvex
And I can see my the functions declared in my dso.
Exactly what do I need to do to get my external vfl files compiled, using my dso?
Thanks.
have you checked if the vexdso file is loaded correctly ?
check the post from symek here http://forums.odforce.net/topic/17495-debugging-vexdso/#entry106118 [forums.odforce.net]
hope that helps
Hi there!
So just to confirm, my VEXdso does seem to be loaded correctly, because in a houdini shell, i can see that my plugin functions have been registered.
It's just that whenever I run vcc externally to houdini, none of my plugin's functions are picked up. I feel there's maybe one essential thing I'm missing like an env var that needs to be set. Couldn't find anything in the docs though…
