Add Frames at the beginning
   7015   6   1
Hey guys!
Most likely super simple question here…
I want to have more Frames added at the beginng of my Sequence.
How can I shift everything further or how can I add Keyframes at the front.
If I try to jus use negative Frames Houdini renders my Flipbooks as Black…
Thanks very much!
Henrik
Okay, I guess I found a Hack by stretching and compressing channels..
If anybody knows a moire useful way to pul this of, I still am interested!
Greetings!
A good tip is to start projects at 100 or 1000 frames in so you can always add header frames to your animation.
Maybe your meant is to use TimeShift :?
With TimeShift you can shift your animation further :!: :idea:
Rabiee.Sadjad@Gmail.Com
Thanks for the response, guys!
I looked into the Timeshift SOP earlier, but it couldn't help me…
The most annoying issue now was that I had some display Flags based on expresions…
Cool - good read at OdForce about it, ‘anim’ explains it a bit down the page:
http://forums.odforce.net/topic/17843-why-does-houdini-start-at-frame-1-instead-of-0/?hl=%20shift%20%20start%20%20of%20%20animation [forums.odforce.net]
Oh yeah! That was very much indeed a good read!
I learned a lot from this mess I made here… New First Frame will be 1001 for the rest of my life ;-)
