Particles and texture color
   6376   4   1
Hello, I would like to emit particles with color based on textured geometry. I got the scattered points color working using uvtexture and vopsop with ColorMap node. Next step is passing the attributes to the particle being emitted. How do I do that?
I'm working on a transition/morphing shop. I would really appreciate it if someone could give me a clue on how to do it. I'm using attractor POP to move the points. Got it. But, color is the problem. Again, I have no idea how to basically do this: emitted particle color based on textured emitter and animating that particles' color to the target textured geometry's color.
Thank you very much.
Did you try “AttribTransfer POP” ?
You can simply do it with this node :idea:
In the attached file I made a simple project about morphing particles from one shape to another shape ,Also these particles can be change it's own color to the Target shape's color when reach to it 8)
I hope it's can be help you
NOTE: I made it in the H12.5 ,So If you use H13 ,You should do it in the “Old-Particle system” :!:
JKParticlesBased_Color.hip (97.2 KB)
Rabiee.Sadjad@Gmail.Com
If you like to change particle's color smoothly from base texture to the target texture ,You can use “AttribTransfer SOP” instead of “”AttribTransfer POP" !
I made these two method in the Attached file for you 8)
JKParticlesBasedColor_Smoother.hip (152.1 KB)
This is exactly what I needed. I really appreciate the time you spent making the scene. Thank you!
rosekim
:wink:
