I can't see my points.
   4333   8   1
Hi
I use macbookpro mavericks.
my Houdini13 is Display points and vertex point, Move point, all points can't see.
but i see Display points numbers! and turn on X-Ray see only object points,
instead of seeing display points numbers so hard.
Why my Houdini points is all gone?
and 3D Viewports - Scene Render option GL1.1, i only got one.
It's normal?
How can i see points? use something else version12?
Please help me :shock:
HELLO!
Can you upload some screen shots and a file that we can test.
What is the graphics card in the MacBook?
My graphics card is Inter iris card. need more graphic info?
2014-03-05 30.29.png (119.4 KB)
HELLO!
and this is turn on X-Ray.
I can see Gray…point
file mean is savefile?
I test other computer. use nvidia graphic
just fine.
macbook only problem… :x
2014-03-05 3.20.png (115.2 KB)
HELLO!
As far as I know, Intel graphics for H13 are limited to GL1, The next version of Houdini will have full support.
http://www.sidefx.com/index.php?option=com_content&task=view&id=2680&Itemid=390 [sidefx.com]
Try setting the environment variable to use the old H11 renderer, that might give points.
HOUDINI_OGL_H11_VIEWPORT = 1
Edit: just remember that H11 viewport does not have all the new features like VDB display and others etc
Thanks!!
How to change…H11 mode.
Houdini Shell.terminal run and type this HOUDINI_OGL_H11_VIEWPORT = 1 ?
or houdini.env file put in HOUDINI_OGL_H11_VIEWPORT = 1
HELLO!
tonakai
Thanks!!
Yes ,Houdini H11 Renderer is Clever Way :wink:
To Active it ,Just Put HOUDINI_OGL_H11_VIEWPORT = 1 in the houdini.env file (in Your Document–>houdini13.0)
Rabiee.Sadjad@Gmail.Com
Thank you all.
HELLO!
Hey Guys!
Also wanted to say thank you!
Had the same Issue! Thanks so much!
This really bugged me!
