Hi all,
I've got a simulation and all looks fine when I'm in the DOP network, but when I go up to the geo level, I see nothing.
The DOP import was all handled by the shelf tools, so everything should be set up correctly. There are no warnings now, but I did have to restart Houdini as the dopimport was giving me a warning before about ‘no DOP object names specified’.
Why is my simulation not showing?
6492 5 2-
- Anti-Distinctlyminty
- 271 posts
- Sadjad Rabiee
- 1391 posts
1. You should put name of your Dynamic Object correctly in the “Object Mask” parameter !
for your file is :
`dopobjscreatedby("/obj/AutoDopNetwork/sphere_object1“)`
for fixed file is :
`dopobjscreatedby(”/obj/AutoDopNetwork/rbdfracturedobject1“)`
2. Because you used Fractured Object ,So you should Turn Off ”Single Object" Option !
Check Attached FIle :wink:
for your file is :
for fixed file is :
- Sadjad Rabiee
- 1391 posts
- 271 posts
That got it! I knew you'd come to the rescue Joker
I guess I changed the ‘single object’ option by accident, but I seriously doubt I changed the path of the object mask.
It's quite annoying for me, when I'm trying to debug this kind of stuff, that I cannot click on ‘Object Mask’ and see what
`dopobjscreatedby(“/obj/AutoDopNetwork/rbdfracturedobject1”)`
actually evaluates to, like I can with other expressions.
- 271 posts
- Sadjad Rabiee
- 1391 posts
