Inheriting velocity in Pyro FX (Houdini 13)
   6194   1   1
Hi guys,
I'd like to get my pyro FX smoke to inherit the velocity of the source geo that it is emitting from. My source geo is a cache with a point velocity attribute. I've seen a few solutions for older versions of Houdini but menus don't see to be in the same places in H13!
Any help greatly appreciated!
well, if you use any shelf solution you´ll see it already inherits the velocity attribute from the emitter.
The Fluid Source SOP does all the work for you reading your v attribute.
It´s strange that it isn´t working.
Could you upload a simple hip file showing the problem?
Javier Meroño
FX TD.
