Hi
I recently bought a graphics card AMD 270X .
I knew amd can have some graphics bugs , but my main idea was to use it for OpenCL simulation .
I tested OpenCL and I think there's a problem .
This card have 4gb ram.When and run simulation on 250x250x250 grid everthing is fine , but on 300x300x300 , drivers crash ( Houdini hang up , or got blue screen from windows )
I think when simulation is taking more than 1GB of VRAM , Houdini crash ( or windows ) . And i monitor this with GPUZ , and Houdini variable to monitor OpenCL memory .
I test this with Windows 7 SP1 and Windows 8.1 .
Another thing i have garbled text in the UI like this thread :
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=140193&sid=9d6dc567c91799a61766e1d6954c0924 [sidefx.com]
In Houdini 13 with AMD's latest beta drivers , the problem is gone , but in Houdini 12.5 problem is still present .
So regarding OpenCL and do not know where the problem is , in Houdini software or in amd drivers .
And is this something that can be resolve in the near future , or I should buy some GTX card ?
I tested the GTX card with 2 GB of VRAM and is working fine , and my plan is to buy a 4GB version , but i dont know that Houdini can use all 4GB of VRAM ?
amd 270x problems(Display , opencl....)?
5380 6 1-
- ginodauri
- 34 posts
- malexander
- 5290 posts
AMD's OpenCL implementation runs in 32b addressing mode by default. You can switch to 64b mode by setting the environment variable GPU_FORCE_64BIT_PTR to 1. This should allow the sim to use the full 4GB (or higher, if you had a card with more than 4GB).
Source:
http://devgurus.amd.com/thread/160325 [devgurus.amd.com]
A change was made in 13.0.259 that attempted to resolve the font problem, but this wasn't backported to 12.5. That could be the reason that 13.0 is in the clear.
Source:
- ginodauri
- 34 posts
- ginodauri
- 34 posts
I red your link that you gave me and there is this:
“So the kernel's binary (ISA) needs 64bit memory access and 64 bit arithmetic for the address calculation in order
to support >4GB of the buffer allocations”
So this is for memory larger than 4 gb , but as i said houdini crash with 1gb.
So i'm now looking into some profesional graphics.
So my question is , does amd firePro cards have same problems like this , if someone with firePro can test this i'll be grateful.
- malexander
- 5290 posts
- ginodauri
- 34 posts
- anon_user_37409885
- 4189 posts
