smoke with "Lambertian" is very slow.
   3523   4   0
Hi, I'm learning Houidini and reading the online tutorial “Working with Particle”.(There is a rocket with particles.)
When I rendered the custom shader “smoke” with the lighting model “Lambertian”, H13 was rendering very slowly.
Is it possible to figure out the problem?
Thank you.
Tony
Do you have a scene you can upload?
You can download the scene to take a look.
Tutorial01_roket.hip (621.8 KB)
Just appears to be a bug in the system - as the Lam. model works fine for normal geo.
You can submit a bug via the Support menu above. Thanks!
Thank you, MartybNz.
I will do what you mentioned.
Tony
