Type Properties Window Maximize stuck
   3463   1   0
Hi there,
I'm encountering this problem when I change the size, at all, of the Type properties window of a digital asset. The window maximizes to full screen, and cannot be minimized or closed. All controls, including the minimize, maximize and close at the top of the screen are cut off, and the accept and save controls at the bottom of the screen also disappear. My only option is to use the window without moving it at all, or maximizing it at all. I tried a re-install with the latest daily build, but the problem persisted. If anyone knows a keystroke that would help me, or a workaround, I would appreciate it.
I fixed the problem, and am archiving it here for anyone who runs into the same thing. To fix it, go into the Houdini preferences and go to the General User Interface tab. Here, you can change the Global UI size to something that accommodates the resolution of your screen, so that the parameter interface window doesn't maximize beyond control.
