How to adjust emission rates in houdini 13 particles?
   4526   2   2
Hi guys,
I have a set of points from which to emit particles from. However, I would like to emit more particles from points that have a higher velocity. Does anyone know how to do that with the new particle source node?
Thanks in advance
Nelson
create group of higher velocity particles at sop level then feed this in popsource dop's Source Group field. Use two stream one for higher velocity and another for normal points. This way you will have control over rate and other things independently.
You can also use pop replicate with “Emit from Attribute” enabled. You can control the emit attribute to control the emission rate based on vel.
Ian Farnsworth
