Call HDA Tool from script
   3676   4   2
I can add tools for my HDA in Type Properties/Tools section.
After than i can use it in shelf anf TAB-menus.
But how to explicitly call this tool script from my custom python functions?
In other words i need to execute Tools/Script (see attached image) section in my functions
https://gumroad.com/alexeyvanzhula [gumroad.com]
i wonder the same,
how you can call a shelf button with python :roll:
Store your code under the ‘python module’ section on your Scripts tab (as opposed to the Tools/Script you have shown. If you have a method defined like this:
def yourMethod():
print “This method is just like so sweet, you guys.”
Then you can access it later from outside of the HDA itself (like from a shelf button) with something like:
hou.nodeType(“Sop/yourhda”).hdaModule().yourMethod()
Documentation for this here:
http://www.sidefx.com/docs/houdini13.0/hom/assetscripts [sidefx.com]
i was wandering more,
let say
if i have a sphere selected, how can i click a pyro shelf button to run with python.
Right click on the shelf button. For instance, Flames.
Click Edit Tool
Click Script
This will show you the code used to drive that shelf tool. For flames, you can see it is:
import doptoolutils
import dopsmoketoolutils
import doppyrotoolutils
doppyrotoolutils.burn(kwargs,True)
Then to see what's going on inside of burn, you can do the following:
add a Python Shell Pane and type:
>>> help (doppyrotoolutils)
That will show you the docstring for each method in doppyrotoolutils as well as the location of the .py source file.
You could take pieces of that code and add it to your HDA, or simply have the build script call doppyrotoolutils.burn(), but I think it might still do the object selection prompting. You'd probably need to tear into it a little for it to use another object.
