ApprenticeHD runs without problems.
When starting Houdini Indie I get an error box:
“No valid licenses were found. Please install a valid license and rerun your application”
I also tried running & re-installing keys as administrator, returning/redeeming ApprenticeHD keys - no luck, same error box.
How do I have to license Houdini Indie with my ApprenticeHD key ?
Solved:
With the help of SESI support, the problem could be solved:
1.) During installation, make sure to select the option to install standard licensing (license server, not local / Apprentice licensing).
2.) Make sure that everything is switched to network licensing (license server):
http://www.sidefx.com/index.php?option=com_content&task=view&id=1283&Itemid=273#local-network [sidefx.com]
In this licensing mode both Apprentice HD & Indie start without problems
