i am trying to recreate a simple paper burning effects but im having hard time figuring out how to generate fire based off a revealing texture map… is there a sample project file i can look at so i can understand the set up? or a tutorial would be great too!!
Example: http://vimeo.com/30525547 [vimeo.com]
Paper Burn Effect Help
13045 4 3-
- Mario Pece
- 1 posts
- old_school
- 2540 posts
Many ways to create this effect. I haven't put up an example using the Attribute Fade SOP ever, so here you go.
Attribute Fade SOP is a nice asset that, given a weight attribute (default name is of type float “fade”) from 0-1, given a blend in and blend out frame length, will reconstruct the fade attribute out for you to fade in and out. I set it up to fade out only. A nice ramp is there for you to re-time the effect.
I use this fade attribute to simply blast points away from the geometry making it real simple to provide a growing band of geometry for the simulation.
The attached solution works in uv space along the object and a direction vector in uv space. Look at the VOP SOP to see how easy it is to do this. I used the Add Attribute VOP in there as I used a Delete SOP in expression mode and needed to add the attribute signature. Shoulda used the Attribute Create SOP to blast the points… Let me know if you want me to add as alternative to the Delete SOP.
- old_school
- 2540 posts
- Lukas Stolarski
- 35 posts
- aaryanguna
- 27 posts
