I am using H 13.0.376 on OS X 10.7 on a Mac Book
When I tried creating a new operator type, finishing up creates the “Edit Operator Type Properties” dialog window but it is taller than the vertical resolution of my laptop hence I am unable to click the accept or other buttons at the bottom.
Any nifty trick to get past this UI restriction ?
Edit Operator Type Properties - dialog too large on OS X ?
4953 5 2-
- nicholas_yue
- 301 posts
- anon_user_37409885
- 4189 posts
There is an app called ‘RDM.app’ that allow you to change you monitor to higher resolutions, on a MacPro you can go todouble the normal monitor res size. It may worth trying it. It also allows you to turn on Retina - HiDpi
http://www.reddit.com/r/apple/comments/vi9yf/set_your_retina_macbook_pros_resolution_to [reddit.com]
- nicholas_yue
- 301 posts
MartybNzUnfortunately, my laptop is a 2008 MacBook (not even Pro), no Retina stuff.
I suppose one more reason to upgrade before 10.7 won't run Houdini ;-)
Cheers
Nicholas Yue
- 4189 posts
- Sadjad Rabiee
- 1391 posts
- fahad64
- 80 posts
