Hey, new to Houdini.
I'm using a Source Particle Emitter and I need to change the size of the particles being emitted.
How is this possible?
Do I change the particles to Geo? Or is it really simple?
Changing particle size
25210 4 2-
- max00
- 9 posts
- Sadjad Rabiee
- 1391 posts
You can change size of the particles in the Render , Not viewport !
To do that you have couple ways , the simpler way is using a Point SOP node in the Geometry Network (Not AutoDopNetwork) and connect the particles to this node , then in the Point SOP parameters in the Particle tab , change Keep Scale to Add Scale , then define your desire value for scale.
Another way is doing that in the AutoDopNetwork with POP Wrangle node :wink:
Of course you can set size of the particles in the viewport via Display Option window –> Geometry –> Point Size
But this is only for viewport !
- Sadjad Rabiee
- 1391 posts
- r0ckman
- 5 posts
- Sadjad Rabiee
- 1391 posts
Hi
Couple of options like :
Simply import position of the Camera in the Point VOP ,Subtract position of the particles with Camera position ,Then Use Length VOP for computing distance of the Camera position and Position of the Particles and export this parameter as pscale attribute.
Also there is a distance VOP node which you can use.
