Bug in Pop Replicate?
   2029   0   1
Hi guys!
I'm having a weird issue with the pop replicate. Please have a look at the file I uploaded so you can understand the situation better. The problem occurs here ‘FONT/popnet/popreplicate1’ in the Birth tab.
For the impulse count I use an expression. This expression works, however, when you change the value of the expression (by multiplying with a different value) it returns an error Invalid group (stream_popreplicate1). Then, when I set the display flag on ‘popcolor1’ and play back the scene, it works…
I'm not a Houdini expert, so before reporting this as a bug, I first want to make sure whether or not this is not just a mistake I made!
Felix
explosions.hipnc (419.1 KB)
