Q about hard constraint and condof and condir
   2914   1   1
Hi!
How does the constraint_type, condof and condir attributes work?
Im trying to create a hinge using hard constraint…so im setting the constraint type to all (to block the falling and to control the rotation), condof to 2 (to restrict the rotation to only 1 axis) and condir to 0 1 0… and my ‘door’ is falling.
Do i have to use two constrains? One to stop the falling, and another to control the rotation?
Attached file contains the scene.
Cheers
-k
constraint.hipnc (95.4 KB)
did you figured out how to do it?
having the same issue
