Render passes for smoke
   3037   1   1
Hi everyone,
Can somebody tell me what are the available render passes for smoke? I've been trying to render direct_noshadow and direct_shadow.
I'm not sure if the direct_shadow works at all…
Thanks for the help!
I think this is OK , Just you should make darker your direct_shadow pass in the compositing !
Also when you wanna render different pass for volumes , when stochastic transparency in Mantra node is On , You should set Sample Filter parameter to Full Opacity Filtering for your pass , If don't that , your rendered pass is noisy !
Rabiee.Sadjad@Gmail.Com
