hello, i have hscript in a shell script
#! /bin/csh -f
#check to see if user suppled the correct number of arguments
#- exit if not
if ($#argv < 4) then
echo “USEAGE: ren_script <hip_file> <out_file> <start> <end>”
exit
endif
# set up user supplied arguments
set HIP_FILE = $1
set OUT_FILE = $2
set START = $3
set END = $4
# start up hscript and allow commands to be sent from C shell
hscript << ENDCAT >& renlog
mread $HIP_FILE
opcd \/out
for i = $START to $END
echo date: `system ( “date” )`
end
ENDCAT
i get a “Badly places ()'s” error. ive tried different combinations of slashes, quotes, etc.
system(“date”) works in the textport.
system() in shell script/hscript
3510 1 1-
- vtwinracersp2
- 30 posts
- Simon
- 2199 posts
It's been a long time since I did any csh with Houdini, but if something works in the textport but not when you script it then it's worth trying to escape stuff that might be parsed before it gets to hscript. In this case the brackets.
echo date: `system\(“date”\)`
total guess though, I can't test this at the moment.
