I'm trying to setup a script wich create some op and I have to get the result op name in case of duplicatas.
Following the scripting documentation I should be able to do something like this:
set sCam = ‘run(“opadd -v cam MyCam”)’
echo $sCam
and get the name of the newly created op.
However, doing this in the Textport, I get as echo the name of the command - and actualy, the command is not executed:
What should I do to have this command executed and retrieve at the same time the actual name of the created op ?
Thanks in advance for any help.
newb script question
4964 6 2-
- grabiller
- 19 posts
- Simon
- 2199 posts
- grabiller
- 19 posts
- RickW
- 141 posts
- grabiller
- 19 posts
- igor_donev
- 133 posts
- grabiller
- 19 posts
