Invalid variable name: FPS
   2895   1   0
listing all the environment variables understood by houdini from ‘hconfig -a’, I've discovered the ‘FPS’ one.
However, trying to set it - with 25 - from a command file ( in a 456.cmd on our HSITE ) I get the following error in the Textport once houdini launched:
MHoudini/houdini7.0/scripts/456.cmd (32): Invalid variable name (FPS)
And houdini is still setted on 30 fps.
Any idea ?
Ok, sorry, this environment variable is only understood by iplay.
I just have to use the hscript command instead:
fps 25
That's said I guess houdini shouldn't complain about the FPS environment variable if it is understood by hconfig/iplay.
