hi,
What different “Current Hip File Only” and “Scaned Otl Directory” when install otl library?
Even choose “Scaned Otl Directory” , It still have to re-install when restart houdini.
Where Install library to ?
8403 5 1-
- jerry7
- 681 posts
- SreckoM
- 381 posts
- jerry7
- 681 posts
SreckoM
In $HOME dir (depends on OS) there is (if not you can create) ‘otls’ folder where you can place otls.
Also you can add custom dir with this env variable HOUDINI_OTLSCAN_PATH.
thank you ! But I still don't known the difference about install to “Current Hip File Only” and “Scaned Otl Directory”. What the options meaning?
- old_school
- 2540 posts
Current Hip File Only = saves asset to Houidni's internal library which is encapsulated inside the .hip file on save
Scanned OTL Directory = assets that reside on disk either using Houdini's environment variables to search for assets on disk on load in one of two ways:
HOUDINI_OPLIBRARIES_PATH := “@”
The path of directories where Houdini looks for OPlibraries files
for loading OTL files at startup. OPlibraries files are only used
if the Operator Type Manager is configured to use them. Otherwise
OTL files are scanned for directly. This path by default is equal
to the HOUDINI_OTL_PATH.
Default path: ‘@’
Where @ is replaced with HOUDINI_OTL_PATH
Directories searched (in order) are:
1) “$HOUDINI_USER_PREF_DIR”
2) “/Users/Shared/houdini/14.0”
3) “$HFS/houdini”
HOUDINI_OTLSCAN_PATH := “@/otls”
This path specifies the directories Houdini will search for OTL files.
This value is only used if the Operator Type Manager is configured not
to use OPlibraries files to find OTL files. The default for this value
is the HOUDINI_OTL_PATH with “/otls” appended to each directory in
that path.
Default path: ‘@/otls’
1) “$HFS/houdini/otls”
The default is $HOUDINI_OPLIBRARIES_PATH.
Default path: ‘@’
3) “$HFS/houdini”
that path.
- jerry7
- 681 posts
- old_school
- 2540 posts
Yes that is correct.
If the asset isn't being used in the current scene, it's definition is not saved the next time you save the hip scene file.
If you want to keep the asset around, put it in your $HOME/houdini/otls directory and it will be there the next time you launch Houdini.
