Just got Houdini and get a long error log evry time i open it. It does not seem to really do anything, i just dont like it.
I have seen the error log pop up several other places, for instance when i ad the houdini ocean and just press play, still it all works.
Here is the error log i get in the console if it helps trace the root of the problem.
Error while populating shelf with shelf tool assets.
File “<stdin>”, line 1, in <module>
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\shelfutils.py”, line 177, in populateShelfFromJSON_ensure_toolbar_dir_exists()
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\shelfutils.py”, line 265, in _ensure_toolbar_dir_existstoolbar_dir = hou.homeHoudiniDirectory() + “/toolbar”
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\hou.py”, line 69088, in homeHoudiniDirectoryreturn _hou.homeHoudiniDirectory(*args)
UnicodeDecodeError: ‘utf8’ codec can't decode byte 0xd8 in position 9: invalid continuation byte
Error while checking for updates
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 84, in wrapperreturn decorated_function(*args, **kwargs)
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\hdefereval.py”, line 193, in wrapper_run_main_thread_worker_thread_code(it)
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\hdefereval.py”, line 152, in _run_main_thread_worker_thread_codeit.next()
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 247, in check_for_asset_updatesinstalled_assets_info = _read_installed_assets_info()
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 635, in _read_installed_assets_info_ensure_asset_store_dir_exists()
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 645, in _ensure_asset_store_dir_existsif not os.path.exists(_installed_assets_info_file()):
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 709, in _installed_assets_info_filereturn asset_store_dir() + “/” + _current_user_dir() + “/installed_assets.json”
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 713, in asset_store_dirhou.homeHoudiniDirectory() + “/asset_store”)
File “C
Exception in thread Thread-1:
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.13\python27\lib\threading.py”, line 808, in __bootstrap_inner
self.run()
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\hou.py”, line 69893, in __threadRunself.__run()
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.13\python27\lib\threading.py”, line 761, in run
self.__target(*self.__args, **self.__kwargs)
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\hdefereval.py”, line 141, in <lambda>thread = threading.Thread(target=lambda: function(*args, **kwargs))
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\hdefereval.py”, line 161, in thread_codeit.next()
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 354, in check_for_shelf_tool_assetstool)
File “C
PROGRA~1/SIDEEF~1/HOUDIN~1.13/houdini/python2.7libs\sas\localassets.py”, line 684, in _shelf_tool_assets_icon_filehou.homeHoudiniDirectory() + “/config/Icons/”,
File “C
