Hi, New to houdini and i have an ocean render issue,help?
   7423   11   2
'CUsers/Dom/Documents/Houdini_projects/Houdini_tests/RE_installed/maps/ocean_displace.0089.picnc'
mantra: Unable to load texture
this comes up when i hit view in mantra
any idea??
is that a valid path?
without seeing your hip file it's hard to figure out what the issue is….
Training Lead
www.sidefx.com
that is where i have set my project? im sorry i am new to this software
i was following a tutorial and did everything they did but i couldn't see the results
Ocean_Test.hipnc (30.5 KB)
This is what the image looks like when it is supposed to be an ocean
please find attached
there is nothing in your attached hipnc file…
can you save it out again?
Training Lead
www.sidefx.com
is this okay?
Ocean_Test_v2.hipnc (961.2 KB)
you have to render the displacements generated by the Ocean Eval nodes > then render the image…
check this tutorial for how to use the Ocean shelf tools
https://www.sidefx.com/index.php?option=com_content&task=view&id=2659&Itemid=132 [sidefx.com]
Training Lead
www.sidefx.com
okay that seemed to help with the scene not making it flat, but it still has a tint of pink to the image?
Unable to load texture ‘CPROGRA~1/SIDEEF~1/HOUDIN~1.258/houdini/pic/DOSCH_SKIESV2_125SN_lowres.rat’
saying this?
select the envlight1
the Environment Map parameter is pointing to an invalid location
$HFS/houdini/pic/DOSCH_SKIESV2_${F2}SN_lowres.rat
$HFS means the location of your Houdini Instalation
for whatever reason this is failing to resolve on your system
it's Windows and spaces in paths - Houdini doesn't like them (nor should it)
it's a pain but I'd really recommend uninstalling Houdini and re-installing
and when the installer asks you where you want to instal Houdini (it will default to “CProgram Files/Side Effects/etc/etc”)
instead use something like
CHoudini14
then in your scene the path to the image will be:
'CHoudini14/houdini_14_0_258/houdini/pic/DOSCH_SKIESV2_125SN_lowres.rat'
HTH
Training Lead
www.sidefx.com
i have re installed houdini like you suggested
but this message still came up in the houdini console
mantra: Unable to load texture ‘CHoudini14/houdini/pic/DOSCH_SKIESV2_83SN_lowres.rat’
Mantra renders pink if it doesn't find texture.
There is nothing wrong with Houdini. It seems that you have “Show sequences as one entry” turned on therefore it's reading file per frame.
you can see it puts ${F2}. Houdini assumes numbers in file name as frame. For single frame it's dangerous.
thanks that sorted it,
i really appreciate all the help thank you
