Hello…
Is there a way to create an alembic cache (with velocity) of the surface preview visible in FLIPtank>Guides>Visualization (check Surface)?
I realize I can import the points via DOP I/O and do a vdbfromparticlefluid, or a particlefluidsurface, but both of these methods are basically reconstructing the surface that is already created. FLIPtank>Guides>Visualization (check Surface) allows me to see the surface, and it is looks better than I can achieve with a VDB or particle conversion.
So can i just spit out the mesh I'm seeing in FLIPtank>Guides>Visualization?
Optionally and perhaps better, how can I achieve the same look using either vdbfromparticlefluid or particlefluidsurface?
Thanks…
Exporting the FLIP surface visible in the Visualization tab.
3289 1 0-
- BrandonRiza
- 13 posts
- CeeGee
- 222 posts
