Unity asset video texture
   5381   2   0
Hi.
How I can control material renderer for Houdini Assets?
For example play video, change color ets.
For material supply I use “unity_material” attribute and material works good. But what if i need play video in some moments or change color and opacity.
If you use “unity_material” you should be able to change the properties on that Unity material inside Unity and have it display whatever you wish. You are now completely on the Unity side. Are you trying to control the texture changes from Houdini?
Yeps. It was stupid question. I find solution inside unity.
