create circle with python
   3657   3   0
hi,
im trying to create a circle using an example from the help(see attached file)..but cant seem to generate the points to make the circle..
not sure where im going wrong, any hints would be appreciated. thanks a lot
python problem.png (200.1 KB)
Maybe it will work better if you actually call CreateCircle() method somewhere?
sorry i forgot to add, i entered the code in a python otl from new operator type…just wondering if you can generate and plot points from that node..
rossl
And? Call the function and it will work. If you don't call it it will not execute. Right now you just wrote the function and it simply awaits there to be called.
Google what calling function means.
