Problem with selection of objects
   2388   2   1
Hi, I recently downloaded the Apprentice version of Houdini 14.0.291 and I'm starting to learning the basics.
I have a problem with the selection tool in the viewports: when I draw a box area over an object, the object its selected, and when I “left clic” on it, the object is not selected. BUT when I have the view expanded (single view mode) I can select objects with the “left clic” method. Also with the viewport configurated in “four views” mode, I can select using this method in the “right” view, but not in the others…
I want to be able to select the objects with one clic but I don't know why this is working only in some views :shock:
I'm in Windows 8.1 and my graphic card it's Nvidia GTX 780
Thanks and sorry for my bad english
Thanks! This has been submitted as bug #(ID=68819)
Until it's fixed you can unchecked ‘Select Wireframe Surfaces as if Solid’ in Display Options/Geometry.
Thanks! I didn't know that option, I'll try it.
