POP Network Error
   3765   3   1
Hi all, I have just started learning and was following the first tutorial but was met with an issue near the end regarding the particle.
I am using Houdini Escape Version 13.0.665 on a Limux OS. While I try to create a POP Network Tool, not only am I unable to create it, I was prompt with the following error too..
File “model_popnet”, line 7, in <module>
File “/apps/Linux64/houdini/hfs13.0.665/houdini/python2.7libs/hou.py”, line 22379, in setName
return _hou.Node_setName(*args, **kwargs)
OperationFailed: The attempted operation failed.
By the way, I tried to delete the preferences (or removing the Houdini folder), it does not seems to rectify it
Is this something that can be easily rectified?
I have the same issue, any chance to get a fix for this?
Is there a solution to this?
Nope, I do not have any solutions, unfortunately
