how can you make Cap segments on a Tube
   6715   3   0
like this ?
(picture taken from 3d max)
You have to create hda (asset/tool) for that.
It's easy.
https://vimeo.com/86717911 [vimeo.com]
https://vimeo.com/86718129 [vimeo.com]
For this simple poly tube, you need 2 extra tubes for caps,
See attached file for simple example asset.
polytube_pz_SOP.hdanc (20.3 KB)
thank you so much
its only easy when you know how.
The easier way is to select both caps at the same time and add PolyExtrude set the inset to 1 and add as many divisions as you want.
