Constrain Hard Body sim to Wire sim?
   1474   0   1
Hi all,
I'm trying to set up a simulation where I shall have some rigid bodies stick to certain locations as much as possible (spring constraint maybe?)
As you can see in the image I have a wire simulation. In that simulation the wire coils around some objects. I need these objects to remain within the coils.
In the file provided there is geometry in obj > chromatin > NUCLEOSOME_CONSTRAINTS. This defines the point locations that I would like the pieces attached to.
tldrl; How do I constrain an RBD fractured object to a certain location?
constraints.zip (3.3 MB)
