Curve intersection with plane
   3996   2   1
Hi all
I need to find the position where a curve intersects a plane.
Any ideas?
Hi, you could give the curvesect SOP a shot. Have a look at the HIP file.
What I found is, that it's best to feed the curvsesect SOP a poly line. Doing so results in a single intersection point. Also, make sure your intersecting geometry is of type mesh or nurbs, etc.
Hope this helps and have fun,
Andy
curve_meets_plane_v01.hipnc (52.2 KB)
It helps, thanks! :wink:
