Houdini 15 Houdini Engine Save bgeo?
   4342   1   1
Does the Houdini Engine API support saving bgeo files?
I want to create a digital asset that will the user to add attributes to a object and save it as a bgeo. Is that possible?
Does the matra node work in the Engine? I want to be able to render images, using Houdini's Manta renderer.
Brad Carvey
Yep, you can bake out bgeos with the HAPI_GetGeoSize() and HAPI_SaveGeoToMemory().
Mantra rendering should also work. You just need to initiate a render via an exposed button (or other parameter) on your asset. Houdini Engine does not expose direct control of Mantra.
