Ho can I use a group inside a dop network?
   1891   0   1
Here is the thing:
I have an object, it's cutted into pieces and I'm defining it as cloth, so far so good, the simulation is running pretty well and I like the effect, now in the Geometry node for that object I create a group called “inside” and in the DOP network I'm trying to limit the “Finite Element Solver” to that group so whne the geometry comes into that group it starts being simulated but if it's not it won't be simulated.
The problem I've found is that the “Cloth Object” node is not importing groups from the geometry, I created also an Attribute wich it's value is “1” id the points are inside that group and is “0” in case they are not but I'm a bit lost on how can I use that Attribute to do what I want.
Thanks in advance for your help!
Cheers.
