Feature Request - Revamped background auto save
   3857   4   1
Nuke, BMD Fusion and others has a great background autosave feature that kicks in automatically, and it's really nice feature. If you have an unsaved comp and Nuke crashes, you get a popup the next time you open it asking if you want to restore the file. If you have a saved file and crash, the next time you try to open that file, you get a popup stating you have a newer autosave of that file and asks if you want to restore that instead.
Now, seeing 90% of this functionality already is in Houdini, what I'm suggesting really is more of a default settings tweak, having autosave on as default, but before having a saved scene file, suppressing the dialog and creating a temp file in the background. What I would love to see added is that temp file check when starting a session, and/or on opening a scene file, checking if there's a newer autosave of that scene available.
And having had similar discussions about other software, I know many argue that this type of thing is redundant if you just organize yourself better, just save your file and use the auto save functionality in Houdini, and though I don't disagree that works, personally I regularly run session with no intention to ever save the scene, just doing small RnD sessions - and though I sometimes save a temp file on the desktop, if I'm just gonna open a session for some quick tests, I often won't bother.
The problem is, sometimes that initial idea of just doing a small test becomes something more complicated, but the initial mindset not saving the file won't really change - and then you do something really stupid and crash Houdini, hehe… And I bet I'm not the only one who does this. :roll:
Oh and ^ this just happened. Because of course that's why I'm posting this!!
~ Messing about with pixels, vectors and voxels since 25 years [vimeo.com] ~
Yep - setting the preference option to 0 minutes would turn it off, and any other value would turn it on automatically.
But how does that solve the breadcrumb issue?
Agreed. This is a standard feature in most serious applications these days. I've been burnt by its absence.
Having auto save on by default could be set up with 456 script.
http://forums.odforce.net/topic/22589-default-autosave/?do=findComment&comment=134027 [forums.odforce.net]
I think I saw some work done about that open crashed/backup file workflow in qLib.
