hey all, I'm exporting “crowd-like” instances to ABC and had a question… If I pass deforming geometry into a Copy SOP then Alembic ROP, all of the nodes in the ABC are instanced correctly.
In practice, you likely want to offset the timing of the instances. Unfortunately, I haven't been able to figure out how to offset the timing and still retain instancing (I've attached a hip). Anyone know how to set this up? thanks!
FYI to check, read the ABC back in and look at the path attribute. if you see “instance” in the name, you're probably good; or you can use python like I do to inspect the file:
import alembic
def visitObject(iObj, tab=''):
printObject(iObj, tab)
for child in iObj.children:
visitObject(child, tab+' ‘)
def printObject(iObj, tab=’'):
name = iObj.getName()
schema = iObj.getMetaData().get('schema')
instance = ‘'
if iObj.isInstanceRoot():
instance = ’instance: %s' % iObj.instanceSourcePath()
print ‘%s%s (%s) %s’ % (tab, name, schema, instance)
f = ‘/tmp/output.abc’
arch = alembic.Abc.IArchive(f)
top = arch.getTop()
visitObject(top)
a correct file looks like this:
ABC ()
geo1 (AbcGeom_Xform_v3)
copy1 (AbcGeom_Xform_v3)
copy1 (AbcGeom_PolyMesh_v1)
copy1_instance_1 (AbcGeom_Xform_v3)
copy1 (AbcGeom_PolyMesh_v1) instance: /geo1/copy1/copy1
copy1_instance_2 (AbcGeom_Xform_v3)
copy1_instance_3 (AbcGeom_Xform_v3)
copy1_instance_4 (AbcGeom_Xform_v3)
copy1_instance_5 (AbcGeom_Xform_v3)
copy1_instance_6 (AbcGeom_Xform_v3)
copy1_instance_7 (AbcGeom_Xform_v3)
copy1_instance_8 (AbcGeom_Xform_v3)
copy1_instance_9 (AbcGeom_Xform_v3)
export ABC instances with time offset
2715 0 0-
- jbudsberg
- 94 posts
