python filtering script doesn't work anymore
   1564   0   1
Hi
I wrote a filter script for mantra command …sometime ago.
import mantra
import sys, os
aPath = os.path.dirname(os.path.abspath(sys.argv))
filePath = aPath + ‘\shad.txt’
mFile = open(filePath,'r')
mLine = mFile.readlines()
sPath = ‘op:’ + mLine
#give this : opshop/myshader
def filterCamera():
mantra.setproperty('renderer:renderengine','raytrace')
#print ‘Renderer’, mantra.property('renderer:renderengine')
def filterInstance():
#print ‘Filtering:’, mantra.property('object:name')
mantra.setproperty('object:surface', sPath)
mantra.setproperty('objectverridedetail', 1)
mFile.close()
All shop are declared but mantra give me a exit code 1 .. even if use directly a shader path instead of the spath variable …
Used to work fine … sometime ago.
Thanks for your help.
Vincent
http://vimeo.com/vbkstudio [vimeo.com]
