Orientation from alembic file - copy SOP
   4395   3   1
Is there a simple way to use the correct orientation objects in the file “alembic” and use the ‘'copy sop’'? I see the axles but I can not use them
G.
Edited by Grzesiek B - June 24, 2016 10:16:01
test_9.abc (25.7 KB)
HIP_abc_copy.hip (194.0 KB)
Your transform matrices are skewed / scaled along one axis.
Here's a workaround to get the correct orient.
Edited by blackpixel - June 24, 2016 18:08:58
orient.hip (313.8 KB)
Thx a lot It works perfectly. But, a next parameter what I need is “Size”. I used “Extract Transform VOP node” for simple extract Scale. At the first glance parameters in Spreadsheet are the same in Houdini like in Maya. When I used copy sop my objects are over scales. So where is the trick ?
Edited by Grzesiek B - July 6, 2016 10:39:10
orient_size.hip (127.7 KB)
sp_anim_v3.abc (140.4 KB)
Also interested how to handle orient and scale from alembic transforms.
