Houdini Environment Weirdness
   9579   5   1
Hi guys!
Sorry for such a long post but I'm currently hitting a brick wall.
I have a strange problem with Houdini 15.5 daily builds. My 15.5.480 installation is working smoothly. The only plugins I installed are the latest Pixar Renderman and the latest Redshift for Houdini.
Some days ago I wanted to give the latest daily build a try. After installation I tried running Houdini Indie and got this message:
After that Houdini crashed.
When I tried to e.g. start gplay.exe this popped up:
My older installation is still running without throwing any errors.
So I did some research and checked my system environment variables. Nothing special there, no reference to anything Houdini.
I renamed my houdini.env (which only contains 5 lines for both Redshift and Renderman, nothing too fancy) and after trying to run Houdini Indie daily it recreated a new houdini.env but still crashed. So it shouldn't be a problem with wrong environment variables coming from there. It also looks like Houdini is looking in the right directory and sees the houdini.env file.
I moved my whole settings (the “houdini15.5” folder in documents) to another place and re-ran Houdini Indie. Still crashing.
I then opened the command line tools, one for the production build and one for the daily.
I typed “hconfig” in both windows. The output of the production build is:
HFS                                        := 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480'
HOME := 'C:/Users/Steffen/Documents'
HOUDINI_DEFAULT_RIB_RENDERER := 'prman20.9'
HOUDINI_DESKTOP_DIR := 'C:/Users/Steffen/Desktop'
HOUDINI_OS := 'Windows'
HOUDINI_PATH := 'C:/ProgramData/Redshift/Plugins/Houdini/15.5.480;&'
HOUDINI_TEMP_DIR := 'C:/Users/Steffen/AppData/Local/Temp'
HOUDINI_USER_PREF_DIR := 'C:/Users/Steffen/Documents/houdini15.5'
HOUDINI_VIEW_RMAN := 'prman'
HSITE := 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/site'
USER := 'Steffen'
the same command with the daily build:
Couldn't find help file: help/config.help
Make sure your HFS variable is set properly, or
that your HOUDINI_PATH includes $HFS/houdini.
hconfig -ap with the production build:
Common paths are set to:
$JOB = <not defined>
$HIP = C:/Users/Steffen
$HOUDINI_USER_PREF_DIR = C:/Users/Steffen/Documents/houdini15.5
$HOME = C:/Users/Steffen/Documents
$HSITE = C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/site
$HFS = C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480
HOUDINI_PATH := "C:/ProgramData/Redshift/Plugins/Houdini/15.5.480;&"
The path of directories where Houdini looks for configuration
files.
Directories searched (in order) are:
1) "C:/ProgramData/Redshift/Plugins/Houdini/15.5.480"
2) "$HIP"
3) "$HOUDINI_USER_PREF_DIR"
4) "$HFS/houdini"
5) "$HFS/bin"
hconfig -ap with the daily build:
$HOUDINI_USER_PREF_DIR = <not defined>
$HOME = <not defined>
$HSITE = <not defined>
$HFS = <not defined>
HOUDINI_PATH := ""
1) "$HIP"
2) "$HOUDINI_USER_PREF_DIR"
It looks like all paths are basically not defined at all and I don't know why. There's a “;&” behind the HOUDINI_PATH in houdini.env so it shouldn't overwrite anything.
I also tried uninstalling Redshift and Renderman and the production build but to no avail.
Does anyone have a clue what's going on here? How can I select the “Set Up Environment” option in “hsetup.exe” that gplay mentions?
Steffen
Ceterum censeo Autodesk esse delendam!
Still happening with the new production build 15.5.323.
Houdini 15.0 daily builds are OK though.
I've posted this as a bug (since I'm experiencing the exact same issue now), let's hope there's a quick solution.
15.5.560 (daily build) seems to work again
Yes, this was fixed several nightlies ago (15.5.539 IIRC).
The latest production build doesn't work.
I had similar error messages with Redshift 2.0.65 and Houdini 15.5.565. Changing the given syntax in houdini.env solved the problem:
HOUDINI_DSO_ERROR = 2
PATH = "$PATH;C:/ProgramData/Redshift/bin"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/15.5.565;&"
